V70 Coil problems
V70 Coil problems
I have taken the car to the dealer twice now after misfiring and stalling problems. Both times the problem was diagnosed as a defective coil. When the coil was replaced the car is ok. Now it has happened again and I am suspecting another coil problem.
1.) Is it difficult to check the coils and how would I know a bad one (cracked ?)
2.) Is there some design defect with the coils or other componants? This seems like an unlikley coincidence.
Thanks,
Bluewindspeed
Thanks,
Bluewindspeed
RE: V70 Coil problems
Yes I have a code reader but this time no check engine light showed. Previously, the code read "misfire" according to the dealer. Is this coil failure a known problem with this car (1999)? Could a defective ECU for example be causing the coils to fail prematurly/
Thanks for you help.
Kim Gregory
02-20-2013 08:02 AM
