V70 Problem - Aux Belt?
Old Jul 20, 2020 | 09:32 AM
Thewilliam's Avatar
Question V70 Problem - Aux Belt?
Hi,
I had my V70 fully serviced two weeks ago and was driving fine until last night - when I went to the car I noticed a small amount of black oil leakage on the tarmac from the passenger side (this could be from the oil change in the service and could be unrelated) then when pulling off after a short journey I noticed a small amount of smoke from the engine. Opened up the bonnet and found very small fragments of rubber which had started causing a bit of a burning smell. On closer inspection the main belt has significant wear on two of the teeth and then to the left which is the auxiliary belt which seems to have completely slipped off causing the wheel to wear on the belt previously mentioned. It drives but really don't want to risk it so it's awaiting AA to come and assess tomorrow. Just thought you guys might have an idea.
Cheers
Belt wear
Oil Leak
Old Jul 20, 2020 | 12:38 PM
Fully serviced? What does that mean?
Looks like someone did not notice your belt was old and coming apart. That used to be part of a 60k service - when was yours replaced last? And hopefully your tensioner and idler are still ok. ( and the p/s, a/c, and alternator!)
amccullough
Nov 26, 2014 09:02 PM
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
Creep
1998-2000 model year V70
Jan 14, 2013 10:35 AM
lukaspanic
Apr 19, 2011 10:05 AM
APSON
Dec 20, 2007 08:24 PM
