V70 vacuum leak
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Been a while since I posted but here I am again. Just bought a 1998 V70 and took it to a mechanic because the engine light was on. He said that the hose in the canister that brings back the unburned fuel is cracked and I need to replace it. Where would I find it?
He also read these codes when he checked the car, PO455, PO302 and PO300, anybody has any idea what it might be.
He's asking a lot of money to fix it and I would like to try it myself, I did a bunch of work on my 240 so I am not completely new to Volvo
Thank you very much
Thank you very much
This thread will give you a good overview of possible problems for the evap leak po455 (at least it's a large leak=easier to find):
http://volvospeed.com/vs_forum/index...d-large-leaks/
If your state does not require emissions testing, I would focus on the misfire codes first to get it running right. The evap codes will drive you crazy and unless the mechanic used a decent smoke machine, I wouldn't fully believe the diagnosis. If you have a shop repair the evap leak, be clear that you are having them eliminate the po455 code. Chances are that it will take more than one attempt to correct it, unless they replace the whole system.
woodsytf
1998-2000 model year V70
08-14-2012 09:25 AM
