Vacuum leak, won't idle
Old Oct 10, 2006 | 02:50 PM
pc142's Avatar
Default Vacuum leak, won't idle
I have a 2001 S80 2.9 non turbo. Before the engine is even fully up to operating temp it begins to have idle problems. By the time she is up to operating temp she won't idle at all. You have to keep up to about 1800 RPM to keep the engine running. When in the garage before this all happens I can hear a vaccum hiss when reving the engine. It sounds like it is coming from center area of intake, under the upper intake manifold area. I tried spraying water around suspect area while my wife reved the engine. Thought I might hear a difference if thr right spot was hit. No dice. I removed the upper intake manifold and inspected thouroughly. Found nothing. Does anyone have any ideas or experience with this problem?
Old Oct 10, 2006 | 05:45 PM
master_pre's Avatar
Default RE: Vacuum leak, won't idle
Have you had the recall software installed. The S80 has a known idle issue with the software.
Old Oct 10, 2006 | 08:02 PM
S70driver's Avatar
I would check your vaccum lines like personally take them off and inspect them. And replace them with Silicone ones from StylinMotors Inc.
Old Oct 10, 2006 | 09:48 PM
pc142's Avatar
No I haven't had the recall software installed. Actually I didn't know there had been a recall, only an extention of the warranty for the ETM. I am going to be contacting the dealer though. I thought maybe I had a different problem because of the slight hiss sound when engine is reved. Thanks for your input.
Old Oct 10, 2006 | 09:53 PM
pc142's Avatar
I did check the vacuum lines and cut off the old ends. Thanks for your thoughts on installing Silicone lines though.
Old Oct 10, 2006 | 11:09 PM
There really isn't many places that will leak on the Non-turbo cars.
Check under the intake good and make sure the big hose is on the throttle body good. Also the small hose off the side of the induction hose.
Also check the hoses off the vent box.
Old Oct 17, 2006 | 03:17 PM
pc142's Avatar
Well I finally cleaned the throttle body. Idles and runs smooth..... for now. Made an appointment for dealer to replace ETM under the extended warranty. They told me nearly two years ago it needed to be replaced, but the $890.00 was a bit much for me so cleaned it instead. Glad it is now covered by the warranty!
Old Oct 17, 2006 | 03:37 PM
master_pre's Avatar
Yeah, that is nice! You may want to look into getting the software just to make sure that you have the most current. I know that my car ran much smoother after receiving the upgrade, and I got all systems loaded for $40.00.
Paulsvolvo
Jul 28, 2015 03:54 AM
robnov
Oct 6, 2007 05:03 PM
nick54
Dec 21, 2006 07:21 AM
speedwagon
May 26, 2006 12:09 PM
hordezla
Apr 14, 2006 08:59 PM
