V70 XC misfire issues
I have a 2000 V70 XC AWD Turbo. About 3 weeks ago the check engine light came on. The Volvo shop said I had several cylinder misfires. So I replaced all the plugs (gapped at 0.028) and even the coils. The check engine light went away on its own and the car was running smoothly. Yesterday the light came back on again. I took it to Autozone to have them check it with their meter (saveed $100 bucks ). The diagnostics were the same... several cylinder misfires, catalytic converter failure and vacuum leaks. The Volvo machanic told me once that the Cat Convrtr failure error is normal when you have misfire. So the only thing that I have not checked is the vacuum leaks. Could vacuum leaks cause spark plugs misfires? or is it something else that's causing the misfires? Thanks so much
Do you think low compression might cause several cylinder misfires? The tester gave possible causes of Random missfires and one of them was vacuum leaks. This is what the tester diagnosis:
Random Cylinder Misfires detected --- Possible Causes:
Thank you for your reply
- Ignition System Fault
- Vacuum Leak
- Injector Fault
- High or Low Fuel pressure.
divinedavis
02-28-2016 06:33 PM
