V70R Ride Height
Ok, I will ask, what will .05 inch really mean for you? I only say that because it is so minimal that I do not really see the benefit. The tires would be the easiest way but then have the speedo re calibrated. The other option is to change to coilovers and adjust the height that way but you will be looking at around $1000 to do so. The advantage to that is when you realize you like it lower then you drop it really low.
0.05" wouldn't matter, I agree. I think 0.5" is meaningful. The car just scrapes on parking entry and on parking "wheel stops" (she destroyed the front bumper by hooking it on one of these sinister things). I haven't exactly measured the problem but I figure if someone can tell me how to raise the car 0.5" I can figure out how to raise it 0.7" if that's what it needs.
Yeah, I've looked at the XC. Problem is it would cost me $20k. And she likes the R motor and R handling. Also there is a big difference between 4.5" of GC and 9"! All I want is 5-5.5". I like the idea of paying more attention, and she's good about that, but no amount of attention changes the breakover angle or the approach angle. If you live in a hilly place you confront this all the time.
I did check the proposed tire solution. I think that could be the way to go. 225/50x17 is about 0.6" more diameter (so 0.3" ride height) and only a 1 mph error at 60 mph. 235/50x17 gets me the 0.5" lift and is a little more than 2 mph error at 60. For that I need to check if the computer can be tweaked for more accuracy.
