knocking
Old May 3, 2009 | 08:20 AM
lesk's Avatar
Default knocking
hi all,
my 2001 v70 auto in the last few days has developed a knocking when driving along which appears to be coming from the front drivers side wheel area. (although inside the car it sounds like the back!)I have had her off the ground and checked the wheel bearings which appear to be ok( no play and no noise when wheels are spun), I have checked drive shaft nuts are tight to 50nm and there are no stones in the suspension. The knocking increases pace with speed and is audible to people outside the car. before I spend a fortune at the garage does anyone have an idea where to look next? Drop links changed three weeks ago and noise does not lessen or worsen when cornering.
les
Old May 3, 2009 | 08:27 AM
Bad tire? Like in broken belt?
Old May 3, 2009 | 08:49 AM
lesk's Avatar
more like regular thumping that increase with speed.
Old May 3, 2009 | 10:56 AM
HMM did it do it when you were turning it by hand?
Old May 4, 2009 | 09:01 AM
lesk's Avatar
no noise at all. Am now convinced noise is coming from right rear, could it be a damper seat gone and causing vibration when moving?
Old May 4, 2009 | 06:41 PM
Maybe a combination of out of round tire and bad top shock mount.
LOVEvolvos
Apr 24, 2012 10:36 PM
tempusfugitive
Aug 31, 2005 07:08 PM
nedvh03
Aug 3, 2005 09:39 PM
don_pam3352
Jun 11, 2005 04:15 PM
ripleydog
Jan 31, 2005 01:26 AM
