2014 steering wheel shakes randomly at 70 MPH
Old Oct 6, 2020 | 07:57 AM
Robert Paschal's Avatar
Exclamation 2014 steering wheel shakes randomly at 70 MPH
2014 XC60 steering wheel shake
My wife's Volvo shakes randomly at 70 MPH. the steering wheel shutters back and forth and it is very noticeable. My wife says its the equivalent of a shake weight without the payoff lol
We just put new tires (all 4 new) on the car this week, new brakes and a new alignment. This was all at the suggestion of the repair shop to fix the issue. Do yall have any ideas what it could be? the car only has 84K mile son it and it has been a nightmare to own. The closest dealership to us is in Houston 90 miles away (we live in college station)
Old Oct 6, 2020 | 10:13 AM
Originally Posted by Robert Paschal
My wife's Volvo shakes randomly at 70 MPH. We just put new tire on the car this week, new brakes and a new alignment.
Steering wheel shaking is caused by out of balance tires. - Sure a worn component can make it worse, but the root cause is tire balance. I would have hoped a worn component would have been discovered during an alignment.
If someone has put tire sealant in a tire to stop a leak that goo can randomly make a tire out of balance - you stated "new tire", was that supposed to be "new tires"?
Old Oct 6, 2020 | 10:30 AM
Correction..... I replaced all 4 tires with new ones, had them balanced, and had the alignment done at the same time. The shaking of the steering wheel is at about 70 mph. Any ideas would help...
Old Oct 6, 2020 | 01:28 PM
Steering wheel shaking is caused by out of balance tires. - And having owned a wheel balance machine and watched employees use it - You need to have the wheel balance checked because you usually don't have your Master Techs balancing tires.
It's also possible you have a bent wheel if they are balanced correctly.
Old Oct 6, 2020 | 02:28 PM
curious what you mean by random - does it change when you apply power, let off the gas or brake? Does it seem to match to road surface? are you driving on regular paved roads or mix in off road etc? I agree with Hoonk that you may have a bent wheel or poorly balanced rim. Did your tire shop also inspect suspension/axle boots etc?
Old Oct 6, 2020 | 04:08 PM
I need to modify my answer - I have seen aftermarket outer cv joints overheat and begin to seize making the steering wheel shake badly - scary badly. But the OP did not mention a replacement axle.
Old Oct 6, 2020 | 04:13 PM
it increases and decreases with the speed at about 60 mph you feel the shimmer. At 70 mph it shakes hard and every so often it doesn’t shake as hard at 70 mph but then it goes right back to shaking hard.
Old Oct 6, 2020 | 04:38 PM
Worn Cv joints can make the steering shake, (have not asked the mileage on the car) but usually only when accelerating and normally not that fast - does the shaking stop when you coast or stop accelerating?
Old Oct 6, 2020 | 06:52 PM
mall breaking and accelerating are fine. It’s just hey way speeds. The car has 84k on it.
Old Oct 6, 2020 | 09:12 PM
E-Volvo-ing's Avatar
My first thought as well was that the tires were not balanced correctly.
It's a cheap and easy fix as the original tire shop should check it for free. If you do not trust them, find another tire shop. Techs who do not correctly balance a wheel is very common.
C30d5
Volvo C30
Aug 4, 2017 02:34 PM
jimduke
Apr 21, 2012 12:48 PM
dman777
Oct 23, 2009 08:37 AM
dogwillhunt
Sep 26, 2008 06:46 PM
bestharry
Aug 16, 2008 11:16 AM
