2018 XC60 Display resetting while driving
We purchased a 2018 Volvo XC60 T6 Inscription in April of this year and it currently has 12-14k miles on it. We took a small trip in early November with only one issue. After getting back on the road from a restaurant the music skipped/repeated on a 1 second loop then stopped and simultaneously the display shut off then restarted. Music picked back up where it left off then a few minutes later it happened once again. After stopping at a quick rest stop a while later the display/infotainment system reset itself twice again. It never repeated the problem until this past Friday.
In all 3 instances the driver profile was set to a profile not paired with a key, the restart happened shortly after starting the vehicle, and was connected to a phone via bluetooth and streaming audio over that phone. Has anyone else had a similar issue? I thought the system had been used in the XC90 for a couple years with no issues. |
Check your USB cable. I had the same thing happen to me with my brand new XC60 and determined it was happening when I used the Amazon USB-Lightning cable instead of the white one from Apple. It could have been coincidence but I suspect it was the cable... it was a bit older/used. So far so good after using the Apple branded one... I’d try to rule it (any old cable) out if I were you. Hope this helps! |
