Auto acceleration XC60 Recharge (2021)
If something else, then you have to be more specific.
If you're talking about when the cruise is set and say; it slows down because of a slower car in front. Then that car is faster or changes lanes, if the coast is clear then the car will accelerate to the set speed unless another car gets in front of you at a slower speed. It's supposed to do that.
Hope this helps.
On xc60 2022 version we have option to enable/disable creep mode.
creep mode on the car will start rolling after depress the brake.
creep mode off the car will not roll unless you press the accelerator pedal.
also can be mistake on gear...
once the car is started the default step to reverse is push
and to go forward is pull twice the lever.
Alexandros (06-02-2022)
