Code 420
Old Oct 27, 2020 | 11:32 AM
dbacheralaska's Avatar
Default Code 420
2014 XC60 3.0 mileage 162000
Got a code for “miss fire cylinder #6” Replaced all plugs and coils. A week later I got a code 420. How do I rule out intake air leak? No antifreeze missing or signs of it in oil.
Old Oct 27, 2020 | 12:11 PM
To find an intake air leak, take a can of carb cleaner (with the spray tube on) and spray around various components and the injector seals - looking to see what gets sucked in and whether it bumps the idle). If that fails go to a local shop who can do a smoke test for you. If that fails you may need to do a compression/leak down test to see if there's ring or valve damage. Did you inspect the wire harness connectors going to the coils? I suppose it could also be an injector (kind of rare but can happen) so you also may try swapping between 5 and 6 to see if the fault code moves to #5.
dougo01
Jun 19, 2019 07:42 AM
pokeita
May 2, 2013 10:29 PM
kyace
Aug 10, 2012 02:39 PM
lockmup
Jun 26, 2008 08:15 AM
dpsa
Apr 12, 2008 02:29 PM
