Engine check light of xc60
Old Mar 17, 2016 | 08:03 PM
SunKyu Lee's Avatar
Question Engine check light of xc60
hello.
I live in Seoul, Korea. so I am not good at English, feel sorry.
I wonder it is normal to engine check light is on when key position is level II.
On key position II, other lamp go on and off for a little.
But engine check light continue to turn on.
Is it OK?
Old Mar 17, 2016 | 09:56 PM
when you are in key position II, all the warning lamps should light as a way of testing the bulbs. Once you start the car, they will go out in a short amount of time. If your check engine light stays on when you start to drive then you need to use an OBD2 code reader to scan for fault codes stored in the car's ECU. Note that the check engine light is different from the service interval light which lights when its time for scheduled maintenance. That light will stay on when the engine starts, but will turn off after a few minutes. Check the owners manual to see which light is the check engine and which is the service indicator.
Old Mar 20, 2016 | 11:05 PM
SunKyu Lee's Avatar
Thank you for response mt6127~
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
