faulty usb replace
Old Apr 18, 2022 | 01:00 PM
iamspuddy's Avatar
Default faulty usb replace
hi
I need some help 2015 xc60 uk. the usb socket isn't working ,I tried to update the sat nav and it doesn't see a usb nor will it charge a phone when plugged in. also the little black plastic thing that surrounds the brass fingers has come out.
So if its faulty any ideas how I get it out without breaking all the plastics .
thanks
Old Apr 18, 2022 | 03:11 PM
b3freak's Avatar
Originally Posted by iamspuddy
hi
I need some help 2015 xc60 uk. the usb socket isn't working ,I tried to update the sat nav and it doesn't see a usb nor will it charge a phone when plugged in. also the little black plastic thing that surrounds the brass fingers has come out. So if its faulty any ideas how I get it out without breaking all the plastics .
You absolutely sure it's the USB port?
Have you tried to looking at the fuse to see if it is blown?
Also, buy some CRC electronics cleaner and clean the area well.
Amazon Amazon
Old Apr 18, 2022 | 05:24 PM
2015 xc60 uk.
You might just need a 30775252 socket. It will go in from the back or the bottom of the console.
Old Apr 18, 2022 | 05:29 PM
iamspuddy's Avatar
ok thanks ,so is there no fuse for this? Also how do I get to the bottom to replace it without breaking anything I couldn't find a video on how to take it apart ...cheers
Old Apr 18, 2022 | 05:52 PM
[QUOTE=iamspuddy;510685]is there no fuse for this?
Also how do I get to the bottom to replace it without breaking anything[QUOTE]
You said it was physically broken, and does any usb device have a fuse?
You take the console apart to get the old one out and the new one in. If you don't have the proper tools or skills you might want to get a garage to do it for you.
Old Apr 19, 2022 | 12:55 AM
iamspuddy's Avatar
skills no problem , but when you can't see any screws and dont know which bits to pull as you dont know where the pop out bits are ,I could do with some guidance...I will buy a new part and the fuse comment was mentioned from a previous contributor which suggested there was a fuse . thanks
Old Apr 19, 2022 | 07:44 AM
Here's photos from VIDA
Old Apr 18, 2024 | 12:36 PM
Mark21's Avatar
hi
thanks
Hey!
have you managed to replace the socket? And it works well? My wifey just broke it in our xc60… . I also have to replace it.
Old Aug 19, 2024 | 04:08 PM
jjw_xc60's Avatar
Thank you "hoonk". Your instructions and pictures did the trick. Don't really need to take out the bracket screws. Can get to the usb socket easy enough. The volvo part was $51 bucks ugh, but fit just fine.
Old Apr 26, 2025 | 11:23 AM
cosimo193's Avatar
I know it's a bit late, but are there any words in VIDA about this? I've got a tool like the one shown, but it's nit obvious what's supposed to happen. I've slid it in as shown in the first picture and met some resistance, but I'm not sure how it's clipped in and don't want to break something.
Cheers
aguruge
Apr 12, 2022 06:17 AM
reizen
Apr 19, 2019 06:52 AM
Starbuck1975
Dec 13, 2017 11:50 AM
Ryfusz
Nov 18, 2016 03:54 PM
Diesel
Apr 11, 2015 04:46 AM
