How to access the fusebox under glovebox in xc60 2018?
Old Apr 16, 2018 | 09:13 AM
alwaysec's Avatar
Default How to access the fusebox under glovebox in xc60 2018?
I tried to hardwire my dashcam with Blackvue's magic power pro. The fusebox under glovebox is behind the carpet. It seems impossible to install the fuse and make the connections without stripping off the whole piece of carpet. Anyone has any comment? I also consider the fusebox at cargo area. However, i couldnt find it (not even with the manual). Anyone can point me to the actual location of the fusebox in the cargo area? Thanks in advance.
Old Apr 20, 2019 | 06:39 AM
tuppa68's Avatar
Hi, did you find out how to do this? I drove to Halfords yesterday to get a dash cam wired in. The assistant found the fusebox under the glove box with the sim card fitting located centrally but he could not work out how to open it. There looks like a hinge on the side nearest the door but this is the side you really want to open it from and so rather than force/damage the cover, he gave up.
Old Feb 22, 2023 | 06:56 PM
VolvoMike46's Avatar
Default Wiring dash cam into XC60 2018
Hi
Any solution for wiring in the dash cam? Mine (a Garmin) needs earth, live and a switched connection. Mike
akam84
Feb 22, 2023 07:26 PM
johnzur@gmail.com
Aug 18, 2019 06:53 AM
cherry_carter
Oct 22, 2018 04:34 PM
David-walker24
Jul 20, 2018 11:01 AM
Ed Ohayon
Jul 10, 2018 06:06 PM
