oil in the boost pipes.
I had my turbo redone had the new cartridge fitted and balanced. de-cat the exhaust and rewrote the soft wear. so the ECU does not see the cat. but i'm getting a lot of oil in the boost pipes. it seems to stem from the breather valve . have you had any issues with the valve before. or is there something else i can look into.
Saleen9090
02-16-2009 05:48 PM
