Safety Recall for backup camera
Old Jul 14, 2025 | 01:59 PM
jeffn's Avatar
Default Safety Recall for backup camera
I received a Safety Recall Notice on June 7, 2025 calling for a software upgrade to fix a "Camera Not Available" issue. My software version definitely is older. I have experienced the "Camera Not Available" message; it usually resolved in a few minutes but obviously the software needs to be updated. I'd like not to have to spend the time going down to the dealer and waiting while they install the software. According to the notice the update will be available OTA. Has anyone done this update OTA? What's been your experience?
Old Jul 14, 2025 | 02:46 PM
jacko15's Avatar
The OTA update is not available in the US. It is available in Europe, but not sure what kind of luck they've had. I got the same notice, and have an appointment this week to have the update done. I'm in the US, and could not get the OTA update.
Old Jul 20, 2025 | 11:37 AM
ceejay22's Avatar
I also got the recall notice, and have experienced the backup camera problem on several occasions, but so far mine has resolved itself by the next time I need to go in reverse.
The recall says the fix will be available OTA "at a later date", so as long as the problem doesn't get worse I think I'm going to wait another month or so and see if the OTA update arrives.
Old Aug 16, 2025 | 01:58 PM
jeffn's Avatar
Update on this post -- the OTA update 3.7.0 was successfully installed early this morning (August 16). When I started the car the entertainment system booted up from a black screen without a problem. Google maps took a while but it's working with all my saved data. The rear cameras turned right on when I backed up. No problems so far.
Old Aug 16, 2025 | 07:18 PM
ceejay22's Avatar
Same here. I was offered the update today and successfully installed it. So far, so good.
Old Aug 17, 2025 | 07:27 AM
mblack154's Avatar
Default Backup Camera
I had the update (3.7) installed on Friday. No one told me that it would "disable" the 360 camera during backup. Called back to the dealership and they said this was normal. So I have the backup camera at the bottom of the screen, but at the top, I see the car with nothing but black around it. I wish they would have informed me of this before the update.
Old Aug 18, 2025 | 05:39 AM
rjwronbo2's Avatar
I also just applied an over the air fix for my 2022 xc60. I received a message indicating I could use my iPhone 16 to download the update. Just like the other respondent it upgraded to 3.7 which according to the safety recall includes the camera fix. After a little over an hour my car was updated. Fantastic since I can now cancel my dealer visit for this Friday.
Old Aug 19, 2025 | 05:19 PM
ceejay22's Avatar
The 360 camera is still available for me after the 3.7 upgrade; it has never been the "default" view when in reverse, but if I shift to reverse and touch in the center of the screen, it either puts up the 360 icon so I can switch, or it switches for me (I can't remember if the secondary touch is necessary in this scenario or not). You might want to check that, if you haven't already.
Old Dec 10, 2025 | 12:28 AM
strurgeongenera's Avatar
I received a Safety Recall Notice on June 7, 2025 calling for a software upgrade to fix a "Camera Not Available" issue. My software version definitely is older. I have experienced the "Camera Not Available" message; it usually resolved in a few minutes but obviously the software needs to be updated. I'd like not to have to spend the time going down to the dealer and waiting while they install the software. According to the notice the update will be available OTA for event entertainment near you. Has anyone done this update OTA? What's been your experience?
Such recalls are critical because a faulty backup camera may display a distorted image, fail to activate, or intermittently shut off, leaving drivers without a clear view of obstacles, pedestrians, or other vehicles while reversing.
Old Jan 8, 2026 | 09:13 AM
ps56's Avatar
Default Recall patch installed "camera unavailable" message has returrned
I had the update installed at the Volvo service center, but I have still occasionally seen the "camera temporarily unavailable" message, even though it flashes and goes away...until last weekend, when I was leaving my parallel parking space within tight confines, and had to resort to using my mirrors to get out of the spot because the message stayed on. Every time Volvo issues an OTA update, I hold my breath, because for every fix, there is usually a regression of another "fix".
stowepotato
Apr 15, 2026 12:16 AM
yaromac
Nov 6, 2021 05:59 PM
JazzDad
Volvo XC40
Jul 16, 2021 12:17 PM
JazzDad
Volvo Recharge Models
Jul 16, 2021 12:16 PM
Jill Davis
Jan 6, 2013 05:59 PM
