System too lean code:P017100
most likely its an intake air leak. First order of business is to inspect vaccuum lines, intake air boots / tubing. You can spray around with carb cleaner to see if it sucks in anywhere and bumps the idle. If nothing obvious shows, a smoke test may be required. Not likely the fuel pump but could be the pressure sensor. A fuel pressure test would be in order - and a proper scan from a full feature diagnostics system like VIDA DICE would help. Injectors are not a common fail item but you can try throwing in a can of Techron with your next tank of gas or run a few tankfuls of a brand name (ie Mobil/Exxon/Sunoco etc) 93 octane to see if the detergents cleaning the fuel system helps. Have you tried clearing the code and seeing how soon the code resets?
jacobrollo (10-13-2021)
