Transmission reduced performance message
? Your photo shows an ABS/traction control warning. (DSTC = dynamic stability traction control) Either way your first step would be to scan the car with a compatible scan tool or VIDA to find out what the control units think is wrong. And then diagnose where those codes lead you.
It just happened to me
This just happened to my 2012 xc60 on 10/10/22. at 330 am ..It was running fine..Then the transmission started to drag then the car started to die on the interstate..I pulled over and the car didn't wantto crank ..and when it did ...and went about 2 feet and died..I had read in this forum that someone had mentioned the battey..The dash was saying the battery was low...I had it towed and the next day I jumped the car off and it ran fine..I took the battery and had it checked since I had just purchased it in February and was told the battery was fine..I don't know what caused the battery drain..But as of 10/12/22 it's running like it did before..Go figure
