Whistling Noise Outer Rear View Mirror
Old Nov 17, 2020 | 07:02 PM
ryanstree's Avatar
Default Whistling Noise Outer Rear View Mirror
Hi everyone,
I've done some searching and found a little information but not much. I recently purchased an amazing 2013 XC60 T6 R-Design Platinum. I love everything about the car but am plagued by one small issue. There is a loud whistle coming from the outside mirror that is more than audible when the window is down. This is mostly from the driver side and I can tell there is some wiggle room between the mirror cover and mirror itself. Has anyone had any issues with this, or better yet, resolving the issue? I have considered replacing the part, part number: 39821919 - outside mirror cover. It's $160 USD and I don't think the dealership accepts returns on painted parts so It would be a fairly expensive test. I've also read of a TSB, TSB RTJ 23801, that is for 2010-2011 of the same model. Any help would be greatly appreciated as I love riding with the windows down but have pretty sensitive hearing and am a bit OCD. Thanks!
Old Nov 17, 2020 | 10:08 PM
ssicarman's Avatar
Use masking tape to cover the seams on the mirror, mirror area one at a time and drive to see if the noise changes or goes away. If doing it around the mirror does nothing then start going further out, door, fender and so on.
Old Nov 22, 2020 | 07:30 PM
ryanstree's Avatar
I taped the small gap at the top of the mirrors and that eliminated the whistling noise. Upon further inspection, after removing both mirror covers, I noticed one of the clips on the inside was broken. Because of this, the mirror cover was not able to be pulled flush with the housing and creates a small gap on the top side of the mirror that causes the whistling noise. I ended up ordering the part pre-painted for my vehicle. I very much hope this solves the issue. I'll touch back with my results.
love2drive
Jan 18, 2019 08:18 PM
dytha99
Sep 13, 2014 05:28 PM
Pumina
Nov 2, 2013 09:46 AM
kpb1216
Feb 14, 2009 11:11 AM
fredgold52
Oct 22, 2007 09:00 PM
