Xc60 2015 hesitation shutter under heavy acceleration.
Old May 16, 2025 | 09:34 AM
Ronald13's Avatar
Default Xc60 2015 hesitation shutter under heavy acceleration.
Need help. Any ideas or have others experienced. Xc60 2015 105k miles. Under heavy acceleration hesitation and shutters. Only hard acceleration and goes away. Maybe when turbo kicks on. If I don't heavy accerlate normal. But when I accelerated faster bucks a little and stutters. Turbo? Spark plugs? Thanks
Old Sep 14, 2025 | 03:44 PM
orygunguy's Avatar
What is the maintenance history of your car? Do you maintain it well? You could have anything from a dirty air filter to a bad spark plug, or a worn plug wire rubbing on something or an unsealed, loose gas cap. Do you have a VIDA 2015?
Old Oct 31, 2025 | 09:29 PM
Chzman's Avatar
Ronald13: I have the same issue on my 2015.5 XC60 with a 2.5 T AWD. Is your car the same model/engine? I had the entire cylinder head rebuilt due to burnt valves, the coil packs and plugs done recently, and the exhaust VVT solenoid replaced due to contamination, but no real solution has been found.
Hoping the smart guys/gals on this forum have some insight and advice on what to look at for troubleshooting.
Old Oct 31, 2025 | 09:31 PM
Chzman's Avatar
How would I get the VIDA 2015 product?
Old Nov 6, 2025 | 10:09 AM
Chzman's Avatar
What was it that you did to fix this situation?
Rdesigner
Oct 19, 2024 12:27 AM
Rdesigner
Oct 17, 2024 07:05 PM
Joycek1
Jul 18, 2024 05:22 PM
grguygr
Nov 11, 2023 04:32 PM
fm3040
Nov 13, 2015 05:45 PM
