XC60 2021 model jack and stand points
I was trying to figure out how can I lift up the vehicle and rest it on a pair of stands. Four jack points, two in the front and two at the rear, are listed on the manual. If I use those points for the jack, where should the stands go? Or where does the jack go if I use those points for the stands. Thanks in advance.
the jack points are for balance and for strength. I'd look at the weld seam and use that If you are using the factory jack, there's probably a slot to hold the jack securely at that mount point so the stand should go as close to that spot under the seam. When I use my floor jack, I usually keep the jack and stand close together and keep the stand close to the mount point but under the seam.
