XC60 Air Suspension
Old Jun 22, 2023 | 05:26 AM
Ian Homer's Avatar
Default XC60 Air Suspension
I have a Volvo XC60 with air suspension and have a question about how low it can be set. The challenge is to enter a restricted height car park with a ski top box fitted. Which mode will allow me to drive the car (slowly) at the lowest height? Or, is it possible to drive the car with the suspension switched off (which I understand is done when the car is jacked up) and if so at what speed?
Old Jun 22, 2023 | 10:34 AM
bertilak's Avatar
Call your local/preferred dealer and ask the service department.
Old Jun 22, 2023 | 11:30 AM
No the suspension turns itself back on the next time the car is started (at least my 2020 did that)
Polestar is the lowest suspension setting - as an alternative you could change the links to make all settings lower.
https://www.ghostmotorsports.com/volvo
Old Oct 17, 2024 | 11:57 AM
BMGD's Avatar
Eco & Polestar Engineered (ie Dynamic) lowers the suspension by 20mm and can be used at any speed, It resets to Comfort when the car is turned off and then turned on again, raising it back up 20mm. Offroad raises the suspension by ~40mm and also resets after a stop/start cycle.
ovlov2022
Dec 15, 2022 06:14 AM
David Santos Barlow
Nov 16, 2022 01:45 PM
wvanellis
Jun 4, 2022 06:22 PM
David Santos Barlow
Jan 31, 2021 05:20 PM
two-saabs
Aug 20, 2017 04:09 AM
