XC60 R design, stuttering under acceleration and at low speeds
Old Jul 21, 2022 | 05:08 AM
stewxc60's Avatar
Default XC60 R design, stuttering under acceleration and at low speeds
Hi, my 2016, 2.4, XC60 r design sometimes stutters under acceleration and at low speeds. Have read that it could be the PEM. Where is the PEM. Has anyone got any ideas.
Thanks Stew
Old Jul 21, 2022 | 09:35 AM
did you check the pressure sensor? are you getting any OBD2 codes? note there may also be a pressure regulator on the fuel rail - not sure for your model/year. On most cars the PEM is back by the fuel tank - have a look around for a "black box" with cables and it may have a triangular mounting bracket... You should be able to find a used one for under $100 if it turns out to be the cause.
Old Jul 21, 2022 | 03:21 PM
stewxc60's Avatar
Hi, no I haven't checked the fuel rail pressure sensor, I'm getting no fault codes what so ever. Its been getting progressively worse. Had all the boot to bits, back seat out. Its the AWD version
yatin.mehta
Mar 28, 2022 09:01 PM
gp24
Oct 12, 2021 07:39 PM
Golicza Patrik
Oct 22, 2020 03:39 PM
Golicza Patrik
Oct 22, 2020 03:38 PM
backlog
Jan 25, 2015 07:43 AM
