XC60 T5 2019 OBD2 reports misfires
Old Aug 1, 2022 | 07:57 AM
XC60T5's Avatar
Default XC60 T5 2019 OBD2 reports misfires
I use OBD2 Car scanner app.
Every trip of an hour it reports multiple (2 till 5) 'Misfires harmful for catalyst'.
What does this mean and is it normal to have some?
Old Aug 1, 2022 | 09:29 AM
Dingus1's Avatar
No it is not normal to have misfires. The car needs to be scanned and diagnosed to see which cylinder is misfiring and why. It says harmful for catalyst, this means the unburnt fuel can gather in your catalytic converter and cause it to lose efficiency more prematurely.
Old Aug 1, 2022 | 01:27 PM
Are you seeing any other codes other than the P030X codes? Is the car running right or does it seem sluggish, getting bad mileage etc? As noted, you should limit your driving and get a proper diagnosis before any serious damage happens.
Old Aug 1, 2022 | 01:42 PM
XC60T5's Avatar
There are no DTC or P codes reported. I just put the sensor data in the app on the dashboard of the app. I'm not sure how reliable this is...
I drove 70 km, 1 hour combined traffic.
The app shows:
- Sensor[ECM]Misfires harmful for catalyst total: 5
- Sensors[ECM]Misfires average cyl.1: 0
- Sensors[ECM]Misfires average cyl.2: 0
- Sensors[ECM]Misfires average cyl.3: 0
- Sensors[ECM]Misfires average cyl.4: 0
Old Aug 1, 2022 | 02:07 PM
Dingus1's Avatar
I would get the car checked with a scanner than can communicate with all the modules and go from there. Are you using at least 91 octane gas as required by the manual?
FAM3857
May 1, 2023 01:23 PM
rickhutz
Jul 28, 2022 01:11 PM
rdgibby
Jul 22, 2022 09:49 AM
gmat
Mar 5, 2022 02:43 AM
johnzur@gmail.com
Aug 18, 2019 06:53 AM
