xc60 tailgate problem
Old Jun 22, 2019 | 08:44 AM
malkiab's Avatar
Default xc60 tailgate problem
hello ,, Dear.
I have problem with my xc60 2010 tailgate door. it is open electronic with hydraulic until reach the top then fall down.
kindly, anyone can help to solve this problem
Old Jun 27, 2019 | 12:27 PM
blindkarma's Avatar
Clean and lubricate the hydraulic door struts with WD40 or similar. It fixed mine when one strut was getting stuck and not opening all the way. Otherwise, if the struts are bad and can’t hold the weight, you will need to replace them.
Old Mar 2, 2020 | 09:45 AM
aaronlife's Avatar
On mine I replaced both struts and that did not fix the issue, so I replaced the pump. After replacing the pump (with a used one from Erie Vovo with lifetime warranty), the tailgate stayed up, but the down button didn't work, so I swapped the module from the old pump to the new/used pump and the down button works again. We don't know if the issue was incompatible software in the new module, or just the new/used module had a glitch with the down button, but if your down button works now, I would buy a used pump assembly (or just the pump itself) and try that. I wasted a few hundred bucks on a new hydraulic strut for the pump, and another $60 or more on the right side strut, both of which must have been fine. A used pump is cheaper. To order a new pump is almost $1000 just for the pump motor. The issue seems to be a bad valve or solenoid in the pump. Try disconnecting the hoses from the top of the pump when the tailgate is all the way up (after just being pumped up), and see if it stays up. I discovered that when the cylinder is full of oil still from being pumped up, as soon as I disconnected the hoses (which have pressure valves on the end), that the cylinder held the tailgate in the place. So it's losing pressure once it's connected to the bad pump/valves. You could also look at where the hoses connect to the cylinder on the tailgate to see if you are losing fluid there, but that might be obvious, you'd see a lot of red fluid leaking.
Old Nov 16, 2021 | 11:47 AM
Eaglecrash2's Avatar
Would bleeding the hydraulic system help? Does it need to be bled? Just wondering
Old Nov 17, 2021 | 10:46 AM
malkiab's Avatar
Unfortunately, couldn’t solved it . Always suffer from tailgate Fall down on my head.
But would you think drainage little amount of hydraulic liquid may fix it ?
Thanks in advance …
Old Nov 17, 2021 | 01:08 PM
aaronlife's Avatar
I don't think bleeding it would help. If there's air in the lines, it will just get in again. Look for obvious leaks on the hoses and fitting ends.
I would start by disconnecting the hoses from the pump by removing the inside panel of the hatchback (with hatchback up after using the pump to lift it, so it remains full of fluid), and see if the hatchback stays up.
If it stays up, disconnected from the pump, then the issue is the valve inside the pump. In that case, the easiest thing to do is call ErieVovo give them your part #s and year etc., and install the new pump with lifetime warranty.
If the hatchback doesn't stay up when disconnected from the pump, then the issue must be something else; maybe the supporting strut, or maybe a bad hose or lift cylinder.
Old Aug 17, 2022 | 10:25 AM
WillKremer's Avatar
Default replace liftgate struts on 2012 XC60 electric with gas
Hi,
I am having problems with the power liftgate on my 2012 XC60 , sometimes works mostly dont. The dealer said its a1200$ job to fix. Is it possible to replace the electric struts with manual gas struts and what type would I need ?
Thank you for any information
Old Aug 17, 2022 | 10:41 AM
aaronlife's Avatar
Originally Posted by WillKremer
Hi,
Does it stay up? If it's just the electric motor that isn't working but the pressure in the system holds, you should be able to use what is there manually. I don't know which strut you would need to replace the power strut.
Describe the symptoms, maybe we can help. Dealer wanted that much to fix mine too, I replaced all my struts, it wasn't that, I just had to order a used pump with lifetime warranty from Erie Vovo and swap it out, not too difficult if you have some tools. If you have an indy mechanic, you could get the pump motor for a couple hundred and pay them an hours labor to swap it if you trust their work. The computer module might have to swap from your old to the new, I had to swap mine, different years were different, even if the pump is the same.
Old Aug 17, 2022 | 11:25 AM
WillKremer's Avatar
Hey ,
Thanks for getting back so quickly with the advice
The liftgate opens with assistance using the button but not from the closed position by itself , depressing the button while raising it manually works and its the same when closing.
The dealer did say it was the pump, I will shop around for a pump and install it myself
Old Aug 17, 2022 | 11:40 AM
aaronlife's Avatar
Call Erie Vovo they have a lifetime warranty on parts. (814) 878-2500
Old Jun 21, 2023 | 01:58 PM
mike91183's Avatar
Exclamation Volvo XC60 Liftgate opens/closes 12" at a time
Has anyone else had the issue where the tailgate/liftgate will only open approx. 8-12" at a time? In other words, we have hit the open/close button numerous times to close the tailgate and finally manually close it. Any advice on how to fix? I've already examined the fuse box and the relevant fuse appears to be in order.
thanks in advance!
Mike
Old Jun 21, 2023 | 02:53 PM
jacko15's Avatar
thanks in advance!
Mike
You could try this:
https://www.volvocars.com/en-bh/supp...a801510088fcc1
chippa8
Feb 15, 2024 11:31 AM
mkastner221
West
Jul 20, 2019 10:28 AM
johnsmclean
Apr 9, 2017 08:25 AM
samiam1955
Nov 12, 2014 07:52 PM
