XC60 Tailgate won't open
Old Jul 27, 2022 | 05:19 AM
MPN's Avatar
MPN
Default XC60 Tailgate won't open
My 2016 CX60 Tailgate won't open using any method - remote key fob, tailgate switch or button inside the car - none. I have a wiring diagram and think my next option is the Tailgate Control Module Unit (my car does not have a tail lift its a manual one :-))- but i don't know where it is ...anyone know where to find it please?
Old Sep 14, 2023 | 05:34 PM
Springbard's Avatar
So what was the fix? I have the same problem.
Old Sep 15, 2023 | 04:19 AM
MPN's Avatar
MPN
The fix was a new tailgate switch - i'd had the unit out and it tested ok with a meter, but when i eventually took the car to a local Volvo specialist thats all he said he changed. Its now fully working.
Old Jul 22, 2024 | 12:08 PM
macjere's Avatar
I know this thread is old, but if you can still see this and still recall, by the tailgate switch, you are referring to the one on the dash for the tailgate and light or the on by the tailgate handle?
Old Jul 22, 2024 | 02:47 PM
Coolllooney's Avatar
its only a micro switch so not much to go wrong and my tailgate lock motor and switch have been replaced and still it won’t open .if I stick a live direct to the plug feeding the motor I can open the boot but then it blows F11 fuse
Old Jul 22, 2024 | 05:41 PM
Springbard's Avatar
I’ll let them respond, but I’m assuming the tailgate microswitch that you press on the tailgate handle.
Old Jul 22, 2024 | 06:17 PM
MPN's Avatar
MPN
Hi,
The symptoms were none of the access methods worked - not the tailgate micro-switch, the boot release in the car (dash) or the key fob. Which made life very awkward when you have two dogs that travel in the boot. Spent ages researching and acquiring wiring diagrams but everything looked ok with a meter. Changed the boot/tailgate release latch, and replaced the wiring harness due to a dog (not mine - son's puppy retriever) chewing the wires when i had the trims off for testing access - none of that worked. Eventually took it to an independent Volvo specialist who swapped bits around with another XC60 and it was the tailgate micro switch (& associated assembly number plate bulbs etc) that was replaced even though it seemed to test ok with a meter. All working fine again now. Incidentally, prior to changing the tailgate unit it seemed to burn through number plate bulbs quite often. May have been a coincidence.
Old Aug 7, 2024 | 08:21 AM
macjere's Avatar
Hi,
Thanks for the response, but did you have a wet floor before the tailgate issue?
Old Aug 7, 2024 | 11:49 AM
MPN's Avatar
MPN
No didn't have that issue.
rmagee213
Jun 22, 2022 06:39 AM
brommerz
Jan 18, 2022 12:06 PM
johnsmclean
Apr 9, 2017 08:25 AM
dougo01
2001-2013 model year XC70
Apr 18, 2016 12:27 PM
Static
Feb 4, 2011 10:28 PM
