XC60 wheel bearing torque settings please
Old Feb 28, 2022 | 04:01 PM
Goodwood's Avatar
Default XC60 wheel bearing torque settings please
Hi everyone. I've just replaced a front right wheel bearing on our XC60 D5 205hp 2009 car.
I'm after the torque settings for:
The bottom ball joint pinch bolt (15mm head)
The suspension strut to the top of the hub 15mm pinch bolt
3x 13mm top strut mount bolts (where the leg bolts to the inner wing)
3x wishbone bolts 18mm (2 go through the antiroll bar bracket & have 22mm nuts on top, 1 has a captive nut)
Antiroll bar drop link nut to strut
Driveshaft bolt
Thanks in advance, Simon
Old Feb 28, 2022 | 11:00 PM
I suspect the XC should be the same:
https://www.volvowholesaleparts.com/s60-torques
Old Mar 1, 2022 | 01:18 AM
Goodwood's Avatar
Default Please would someone be kind enough to look it up
Hello, thanks for the suggestion. I'd like to know for sure what these are though. Especially the pinch bolts. I've known of castings break or let go before if these are wildly wrong. A diagram with the torque settings would be perfect, but id like it for a 2010 xc60 D5 please AWD 205bhp
Jj001
Aug 6, 2021 01:38 PM
jabbo
Jan 15, 2017 07:58 PM
porkchop112699
Jan 12, 2014 02:23 PM
Bearbacker82
Mar 18, 2012 06:55 PM
johntua1
Nov 13, 2010 02:50 PM
