1998 XC70 ebrake cable
Old Jul 4, 2007 | 02:00 PM
jay philoon's Avatar
Default 1998 XC70 ebrake cable
Replacing the rear brakes pads and rotors. The emergency brake shoes were worn out so replacing those as well. Seems like the ebrake cable is stuck - no matterhowtightly I adjustthe emergency brake handle nothing seems to be happening at the rear wheels. Lots of rust at the wheels, by the way. Think the cable is rusted stuck? What do I do? Can I open up the center console and free up the cable by pulling on it or something? Anyone had experience with this?
Old Jul 5, 2007 | 12:50 PM
billofdurham's Avatar
Default RE: 1998 XC70 ebrake cable
Working from memory, the e-brake shoes are adjusted first at the wheel by turning the disc until the adjustment hole is over the adjuster screw between the shoes. Adjust the shoes by turning the adjuster upwards until the disc will not move then slacken the adjuster 4 - 6 notches. Do the otherside in the same way. Only then should you need to consider adjusting the lever, which is done by removing the square cover plate in the base of the centre console armrest, giving access to the parking brake lever adjustment screw.
Turn the screw so that full braking effect is reached between 2 and 8 clicks on the ratchet.
Old Jul 6, 2007 | 09:55 AM
Thanks. In the end, I had to replace the emergency brake cables.
bbruno
Jul 30, 2009 12:44 PM
WRVolvo
Mar 27, 2009 07:41 PM
sdcromer
Jul 2, 2008 12:59 PM
Cambridge Volvo
Dec 5, 2007 04:24 PM
mikhailarey
Jun 19, 2005 10:56 PM
