1999 xc70 cranks, won't start
Old Jan 14, 2011 | 02:40 PM
r12mike's Avatar
Default 1999 xc70 cranks, won't start
Running fine, then parked overnight in 20 degrees, cranks but willnot start.
I have verified good battery, good spark, fuel pump can be heard initiating,
reset alarm ignition lock out (cycled locks 5 times), checked fuses,
and still working on it.
Plan to check cam sensor leads, anti tilt switch, etc., etc.,
any and all suggestions are welcome.
Old Jan 25, 2011 | 08:27 PM
nelsonent1's Avatar
Default won't start???
Do you still have a problem starting? Check fuel pressure at the fuel log... there is a valve stem looking/function on the fuel log... if so then check spark.
nightmarevolvo
Feb 4, 2023 06:20 PM
Luvmateo
Nov 30, 2014 08:22 PM
blamaustin
Feb 1, 2011 04:05 PM
rainman14624
Sep 20, 2010 09:22 PM
Andy
Nov 19, 2007 10:23 PM
