Climate Control Light
Hi There - first post. 2001 V70 XC The climate control vent selector (little guy sitting in a seat) won't light up. All other buttons and switches work fine and the selector works fine - junt not lit up.
Any ideas? |
RE: Climate Control Light
there is most likely a light bulb out back there. you would need to pull the radio / climate control panel out. pull the trim arround the gear selector up and there are 4 clips on the bottom of it to take it off. then there are 2 t25 screws holding the radio in. pull the bottom out and the top will follow. most of the time you will need to put it in drive to get enough room.
