Climate Control Light
Old Nov 10, 2008 | 01:02 PM
macgiles's Avatar
Default Climate Control Light
Hi There - first post. 2001 V70 XC The climate control vent selector (little guy sitting in a seat) won't light up. All other buttons and switches work fine and the selector works fine - junt not lit up.
Any ideas?
Old Nov 11, 2008 | 06:27 PM
Pearsonmx6's Avatar
Default RE: Climate Control Light
there is most likely a light bulb out back there. you would need to pull the radio / climate control panel out. pull the trim arround the gear selector up and there are 4 clips on the bottom of it to take it off. then there are 2 t25 screws holding the radio in. pull the bottom out and the top will follow. most of the time you will need to put it in drive to get enough room.
sly_fox
Mar 14, 2011 02:28 AM
Stripes
Dec 11, 2010 05:50 PM
Vitruvianman
Dec 16, 2009 04:03 PM
jfikentscher
May 31, 2006 09:58 PM
