A couple of questions
I finally got one for myself! I bought the kids a 1985 240 wagon a few years ago and its still running strong, but now I have my very own 2004 XC70. Everone asks if I'm starting a new family, since I already have 4 kids and 6 grandkids, but I'm a percussionist and there's so much room for all my toys! What a great vehicle.
So. Do I need to just go buy the roof rail adjustment tool from the Volvo dealer? They want $18 for the thing which is little more than a glorified proprietary screw driver. Are there any other sources or a work-around? Is there anobody here who can tell me exactly what the differences are between a V70 and an XC70? I usually see things like: The XC70 is a bit taller due to its AWD.. but then I see countless AWD V70s! Even this website states: "The only real difference between the Volvo XC and the V70 are a more styled body type and the fact that the XC is a 4x4." They might want to change that. So.. whats the real scoop? Some suspension tuning? Different tires? I can't spot any trim differences. Even a local Volvo mechanic laughed when I started to correct him, saying "Its an XC70." when he wrote down V70. He said.. "We just call them V70s." Many thanks. |
RE: A couple of questions
I just use a torx 27 screwdriver with a security hole drilled out in the center of the bit.
ORIGINAL: Bigtrev I just use a torx 27 screwdriver with a security hole drilled out in the center of the bit. Is it necessary to drill out a security hole in the center in order to make the torx head fit? |
No they make that tool you should be able to find it from any tool supplier. Its called a security torx I believe. Just make sure its long enough to reach back to the screw. I got mine from snapon tools.
