Factory hitch question?
Is this a European spec vehicle? NA spec vehicles have a receiver hitch. Euro-spec vehicles often have a hitch receiver shaped like a small, flat rectangle hidden behind the rear bumper in which the hitch slides UP into.
That being said, you could always have the hitch now on the vehicle removed and have U-Hual bolt on a 2" receiver hitch.
That sounds like the standard NA spec hitch, made up a square 2" receiver into which you slide the hitch bar/ball. When the bar is not installed the receiver (the hole) is plugged ith a black rubber plug stamped VOLVO. Pull out the rubber plug and you can install any receiver type bike rack, such as those made by Thule, Yakima, Saris, Kuat, etc. You only use the hitch bar and ball if you want to pull a trailer.
When I remove the plastic cover I see a round (male end) receiver and in the tool kit with the spare tire there is a L shaped cast piece with a tow ball on the end that fits over the round part and locks in place, The original window sticker shows it to be a N/A car. In the owner's Manual under TOWING it also shows the hitch.
