Headlights always on
I recently purchased a 2001 XC 70. The headlights are always on. In the owners manual it says that this can be changed so that they will operate normally. Does anyone know how to make this change.
The DLR feature keeps all of your lights on all of the time that your key is turned on. That means if you are working on your car's electrical system and need the key to be on your battery is being drained. If you turn the switch to the parking light position that turns the other lights off but you will inevitably forget to turn them off and the next morning your battery is dead. Also, automotive bulbs are not cheap. And finally, keeping your headlights on all of the time means heat buildup that will fry your connectors. just replaced 2 of them on the dim lights, the connectors were so brittle from the heat they crumbled. You can get the DRL turned off at the dealership... for a price. Volvo makes nice cars and then goes far out of its way to make things inconvenient and expensive.
Swer
Jan 9, 2015 09:50 AM
tennisguy
May 18, 2006 07:32 PM
