A/C always on?
Old May 30, 2006 | 03:36 PM
AaronD81's Avatar
Default A/C always on?
My brother just bought a 98 S70 GLT and the compressor seized so Volvo put on a new one, new accumulator, and acc belt. Even with the A/C button showing off the air blows ice cold and the lines have condensation on them. I assume it's electrical, what should I check or replace? The bill for a new compressor was $1300 so I'd rather check stuff myself than take it to Volvo first. I also am assuming thts what caused the compressor to go bad, or at least faster than it should have. Usually I wouldn't worry too much but when it seizes you can't drive the car.
Old May 30, 2006 | 11:13 PM
Default RE: A/C always on?
HMM that is very weird.
You will have to trace it back to the Module in the Dash.(A/C controls)
Never seen that before. The Low pressure sensor wire must be getting power from somewhere.
Old May 31, 2006 | 08:57 AM
AaronD81's Avatar
Are most of the electronics in the A/C switches? I thought about replacing it but didn't know how much was in the controls and how much was located elsewhere.
Old May 31, 2006 | 08:52 PM
There is 2 switches in the system. But they all receive signal from the Controls.
There is a high pressure switch and a Low pressure switch.
Do you have ECC or MCC?
ECC has AUT by the switches and ***** also have Temp in Numbers.
MCC just has speeds in Numbers and Temp in colors.
Old Jun 1, 2006 | 08:39 AM
AaronD81's Avatar
It has ECC. So would you recommend I replace the switches first or the controls? Thanks.
Old Jun 1, 2006 | 08:41 PM
ECC the switches are part of the Control module.
Expensive to replace.
Do you have a wiring Diagram of your car?
Old Jun 2, 2006 | 08:45 AM
AaronD81's Avatar
I'll check, I have a Haynes manual and one on CD. I think the Haynes has wiring diagrams. I have a 98 V70 so I could trade them out just to troubleshoot.
Old Jun 2, 2006 | 08:39 PM
If not look at the Link.
http://www.volvotechinfo.com/WD123/
m4gician
Oct 17, 2008 03:45 AM
hordezla
Feb 10, 2007 10:37 AM
mgimza
Nov 14, 2006 09:11 PM
tennisguy
May 18, 2006 07:32 PM
barge
May 12, 2006 10:55 PM
