Help getting lower bolt out of lower back engine mount
Old Apr 5, 2022 | 12:39 PM
Andrew_sanstrum's Avatar
Default Help getting lower bolt out of lower back engine mount
I’ve been replacing all of the engine mounts in my 2004 XC70 and the lower bolt on the rear lower engine mount is giving me a horrible time. I’ve tried using a swivel socket and an extension but there is a bar getting in the way of the extension and the swivel is not enough. I was thinking of using a crows foot or some other tool to get it. If any of you have any advice or experience doing replacing them let me know if you have any tips or suggestions
Old Apr 7, 2022 | 10:00 PM
Default Solution
I ended up enlarging a hole in the subframe with a stepper drill bit to about 1/2 to get a 3/8 extension through and using a 15mm swivel socket to get at the bolt. I was desperate at this point after using a bendy extender and bending it permanently. I’m going to put in send over the exposed metal to make sure it doesn't rust
jantariq
Penta
Nov 13, 2020 03:37 AM
burakuysal
Nov 24, 2013 05:52 PM
rmjryost
Nov 14, 2009 03:07 PM
gilber33
Jul 14, 2009 07:31 PM
strangedays
Sep 29, 2007 09:53 PM
