Leaking Clear Viscous Fluid @ 1,600 miles!
Old Jul 26, 2008 | 09:39 PM
2008_XC90_AWD's Avatar
Default Leaking Clear Viscous Fluid @ 1,600 miles!
Arrived home in 2008 XC90 AWD 3.2 with only 1,600 mileson Monday to find fluid leaking from engine. Put several pans and next morning found CLEAR viscous fluid (thus not water) with a yellow-brown scum on top in the pan under the left forward section of engine bay; light brown oily fluid in pan under right forward section of engine bay. Towed it to authorized service center (1-man shop nearby), then had to tow it onto Hawaii Superferry to Volvo dealer on island of Oahu this weekend. The local shop insisted it was condensate and oil, but the clear fluid I collected was definitely not oil, but very viscous. Is this the Haldex AWD fluid? Oil plug, filter, etc. all tight. I assume if it was tranny, it would be red.
Old Jul 27, 2008 | 03:24 PM
2002XC70's Avatar
Default RE: Leaking Clear Viscous Fluid @ 1,600 miles!
It doesn't matter WHAT the fluid is, it shouldn't be there, at least in my humble opinion. A new Volvo should have passed quality assurance people at plant. Did you by any chance hit something or did something off the road bed flip up and hit your underside? Regardless, you were smart NOT to drive it but tow it. For sure let a Volvo dealer handle it from here out. Again, take this for what it's worth, I am no authority, just using common sense.
My 2002 XC70 leaks ZERO anything/anywhere/anyplace. So your case sounds abnormal.
Old Aug 18, 2008 | 10:14 AM
Rascal2pt0's Avatar
My guess is for power steering fluid. I don't know anything about Volvo AWD, but if they use a viscous coupler like Subaru it could be that leaking as well.
BILL_MCCASSEY
Oct 1, 2023 02:52 PM
Chrispy_T
May 22, 2013 03:39 PM
rllittl1966@yahoo.com
Dec 4, 2011 01:24 PM
2008_XC90_AWD
Jul 26, 2008 09:36 PM
mrscullini
Feb 24, 2007 02:58 PM
