Moisture in headlight
Old May 18, 2010 | 07:36 PM
family XC70's Avatar
Default Moisture in headlight
My driver's side headlight has moisture developing rather quickly inside the lens. I did replace the parking light/turn signal a while back. What is the fix for this, new lens? Just curious if anyone knows of an easier fix out there?
Old May 18, 2010 | 08:50 PM
SVTfocusO3's Avatar
water test the seals, this does not usually happen.
Dry it out with some alcohol/water mix. requires removal.
Old May 18, 2010 | 09:12 PM
Moisture building in the lights means an air leak somewhere.
You said you replaced the parking light?
If this is on the 01 in your sig then the headlight and parking light is all one assembly.
The glass might not be 100% sealed somewhere.
On the older cars when this happened we drilled small holes under the headlight where you would not normally see them. That would stop the moisture from building up in there.
Some newer headlights have vents in them which is supposed to stop it as well but does not always work.
jojoswhip
Apr 24, 2009 02:35 AM
Jimbo_Jones
Apr 20, 2009 08:07 PM
jmc_gtr
Feb 26, 2007 12:33 AM
casique
Feb 13, 2007 07:47 AM
indiana
Mar 12, 2006 02:13 PM
