new trouble codes, any thoughts?
'00 v70xc, 85k miles
pulled a couple new trouble codes this evening, any thoughts/advice/insight? thanks p1238 p1550 a brief search seems to reveal that the p1550 may be related to the abs mod. i intend to have it repaired soon. |
RE: new trouble codes, any thoughts?
the other night i sprayed a couple shots of carb cleaner into the air intake past the maf sensor. i did this to clean the maf sensor. i had been told to do this by mechanics for other vehicles in the past. don't get me wrong, this was not an entire can of carb clean, just a couple shots. do you think it could cause damage to the turbo or etm? do you think it could cause these codes to trip?
as usual a quick search reveals a lot of info. it seems there is a bit of controversy over carb cleaner and tb cleaners. for now i going to assume there was no major damage done and that my new codes are not related.
aside from the codes, the car is running fine (knock on wood). |
Well when I clean my TB or sensor I don't use spray. I use a carb solvent or even a degreaser and a toothbrush or acid brush and gentley massage the dirt away. But I don't think carb spray would effect the codes you mentioned. I heard of some solvent messing up certain sensors. look on the bottle and make sure it says sensor safe. just a bit of info...
