Oil Drain Plug Gasket Dimensions
Old Feb 12, 2011 | 09:22 AM
qlopp's Avatar
Default Oil Drain Plug Gasket Dimensions
I am looking at purchasing a 2004 XC70 and have a question which I couldn't find an answer to by searching here. I'm trying to prepare my maintenace supplies incase I buy this car.
The only source of info I have on the engine oil drain plug gasket size is via Pelican Parts, and they list it as 18mm ID X 24mm OD X 1.5mm thickness. If that IS true then I already have a box of aluminum gaskets that size from my previous and current asian vehicles that use that size on differential and transmission drain plugs.
Can anyone verify the gasket size for the 2.5L inline 5 engine? Thanks!
Old Feb 12, 2011 | 12:01 PM
ed7's Avatar
ed7
Most filters sold come with an o-ring and crush washer. Sounds about right. I reuse mine at least once.
Ed
Old Feb 12, 2011 | 06:10 PM
qlopp's Avatar
Ed
http://www.amazon.com/Mann-Filter-HU...7555374&sr=8-1
Mann is what I will use if I get the car. As you can see from the pic in the above link a crush gasket is not included in the HU819X kit.
Does anyone know whether the ID of the drain plug gasket is 18mm or ?
whgarner
Apr 9, 2011 12:13 PM
Golvo
Nov 16, 2010 08:17 PM
Gregg
May 13, 2010 09:02 AM
Bobec
Nov 7, 2009 06:59 PM
crunch5868
Jul 24, 2008 12:28 AM
