P0234/p0236
Old Jun 11, 2009 | 10:57 AM
sjonnie's Avatar
Default P0234/p0236
My '02 XC70 140K mi is showing the following codes. I can reset them but eventually they come back,
P0234/ECM-6805 = Turbocharger (TC) control valve, boost pressure fault. Pressure too high
P0236/ECM-170F = Atmospheric pressure sensor / boost pressure sensor range check. Faulty signal. Intermittent fault
Additionally, the engine is not happy with whatever is wrong. It idles okay but occasionally seems to get a hiccup causing a large amount of vibration and almost a stall, which it has done once. The random vibration thing has been common on my engine for a while, the stalling and codes are new so I guess it's a developing problem.
The boost pressure control valve makes an audible clicking sound, presumably as the solenoid switches on and off, although I don't know if that indicates normal function or not. Replace? I checked the MAP connections but they seem fine. The fact that I can reset the P0236 code without it immediately reappearing suggests that the MAP sensor itself isn't bad, could it be the boost control valve? Any other ideas, diagnostic tests I should try?
tactic
Oct 12, 2012 01:04 PM
mark458
Sep 29, 2010 07:34 AM
cowenstaff
Nov 2, 2009 06:00 AM
Anns V70
Sep 7, 2006 11:53 PM
