P0302
Old May 4, 2022 | 11:48 AM
Bzingram's Avatar
Default P0302
I received that code. I changed all spark plugs and coils. Still got the code for cylinder 2. I want to know if I should check the injectors , or is it wiring most likely. I checked the wires and they don't seem worn out.
Old May 4, 2022 | 02:39 PM
what year/engine is your car? Do you notice any performance issues or other symptoms or is it that you are getting the CEL and it won't go away.
A P0302 is saying a misfire was detected on cylinder #2, which can be caused by ignition, fuel delivery or compression issues. Injector issues are not all that common but you can always try swapping #2 and #3 to see if the fault changes. As to wires, I assume you are referring to the harness that powers the coil? you can look for cracks in the connnector and clean the contacts to #2. After that you may want to measure fuel pressure at the rail and consider doing a compression test. Any signs of coolant loss with no visible leaks (suggesting a head gasket issue)?
Bzingram
May 3, 2022 12:43 PM
pokeita
May 2, 2013 10:29 PM
dlaxdal
Aug 12, 2011 07:44 PM
seetrout
Feb 17, 2011 12:27 AM
s40driver01
Nov 7, 2006 11:12 PM
