Shift Knob Repair
Old Jun 27, 2007 | 12:19 AM
Psaboic's Avatar
Default Shift **** Repair
Cna anyone tell me how to remove and then replace the transmission shift **** on a 2001? The button in the shift **** has broken, and I want to see if I can fix it or not.
Specifically I could use instructions on
1. How to remove the **** without damging anything
2. Quick and effective way to repair the ****/button
3. Replacing the **** so it all works agian <grin>
Thanks,
Glenn
Old Jun 28, 2007 | 02:53 PM
S70driver's Avatar
Default RE: Shift **** Repair
1. If it is anything like the previous shiftknobs in Volvo's. Like the ones in the 95-99 models that I have seen. Then what you have is a leather shiftboot. Which you need to twist at the bottom of the actual ****. I forget which direction. It should turn and then you pull it down. Next you need to pull the shift **** straight up. Yeah your going to have a fit trying to do this. Might even break something in your body and or in the car. I'm not joking about this, automatic shift ***** in Volvo's are a true pain to remove. GOOD LUCK!!!
Old Jun 29, 2007 | 08:51 AM
Psaboic's Avatar
Whew...It seems I got lucky. I was able to repair the button with some epoxy resin. Hopefully it will last as removing the **** sounds really painful!
Glenn
FirstV70Volvo
2001-2013 model year V70
May 13, 2013 08:04 PM
jfspring
Jan 29, 2006 12:00 AM
Superfly
Jan 18, 2006 01:15 AM
jcmartin
Sep 20, 2005 08:54 PM
ZIGZAG
Aug 3, 2005 09:56 PM
