Talk me into...or out of... an 03 XC70
I have no idea why I have become enamored of the Volvo XC70, but now I think I want one. One in particular that I have an eye on is an '03 with around 150k mi. I can do all maintenance, some repairs, but I'm leery of buying a brand I've never owned and don't really know that much about. In addition, the nearest dealer is probably 110 miles away.
Is this a normally reliable vehicle? And without a nearby dealer, is it possible to diagnose problems and repair in the ole home garage, or are you dependent upon the dealer? Can I expect to get 225k out of this vehicle without major problems? I'm open to either side of this debate. If I need to give up the idea, I will. If I get some encouragement, I might just give it a go!! |
It would be the acme of foolishness to set about such a thing without planning to get a volvo scan tool that can talk to all the computers on the car. If you do that I think you'll be fine. They're needy, but as long as you do all repairs yourself, I think they're okay. There are some unique problems with the AWD system according to google, but apparently the expensive ones are not a must-fix situation.
Well, I posted this almost a year ago, and as it happens, I found a Saab that I took a chance on. I'm not entirely dissatisfied with that purchase, but I seem to gravitate back to my original notion of a Volvo. I'd like to find an early '00s XC70 or V70, but may be open to a S60 or S80. I read a lot about timing belts on this forum and other sites. Is the I-5 an interference engine? Aside from the timing belt, are there any other notorious problems (turbo failures, ECU problems, etc.) that I should be aware of?
They are interference engines.
The turbo are very reliable if they have been properly maintained. But if the previous owner didn't change the oil enough, you coul have turbo problems or PCV issues. |
Originally Posted by ES6T
(Post 450622)
The turbo are very reliable if they have been properly maintained. But if the previous owner didn't change the oil enough, you coul have turbo problems or PCV issues. As to interference engines - An interference engine is one that has insufficient clearance between the valves and pistons if the cam stops turning due to a broken timing belt. The result is usually catastrophic engine failure. Not so with a non-interference engine. |
Originally Posted by bolt snapper
(Post 437090)
Is this a normally reliable vehicle? And without a nearby dealer, is it possible to diagnose problems and repair in the ole home garage, or are you dependent upon the dealer? Can I expect to get 225k out of this vehicle without major problems? I'm open to either side of this debate. If I need to give up the idea, I will. If I get some encouragement, I might just give it a go!! http://forums.swedespeed.com/showthr...ations-on-XC70 |
No one here is going to talk you in or out of anything. Buy whatever makes you happy. Volvo has sold hundreds of thousands of vehicles. There are plenty out there.
