V70XC Fuel pump
Old Sep 7, 2011 | 07:02 PM
reinbeau's Avatar
Default V70XC Fuel pump
I just purchased a V70XC. The seller told me that his mechanics told him it needed a new fuel pump. The indicator being that when I turn the ignition switch it doesn't crank the first time but does on second try. My questions is does it need a new pump or a fuel sender unit? The expense difference it huge.
Old Sep 8, 2011 | 07:47 PM
VTBricked's Avatar
You say it doesn't crank on the 1st ignition try. Do you mean it doesn't start? I'm also not sure why you're second-guessing a mechanic - check the fuel pressure if you're not convinced or talk to the mechanic to find what diagnostic was done. A fuel sender issue would not cause starting problems, just fuel gauge reading.
wilddog
Feb 20, 2022 04:18 AM
patarack
Nov 23, 2011 11:03 PM
spidersilva
Aug 17, 2011 07:23 PM
jklenk
Aug 18, 2008 12:26 AM
