Volvo xc70 stearing rack
Old Mar 19, 2023 | 04:55 AM
Userguga's Avatar
Default Volvo xc70 stearing rack
Hello!
I have xc70 2000 year P2 2.4 t 147kw car. Can I use xc90 2002 year steering rack, however it's may steering rack is 84cm long but xc90 86cm .
Old Mar 20, 2023 | 09:36 AM
PixelDust's Avatar
To be honest, I don't really know.
I do know you can swap CV Axles and strut assemblies from XC-90's➡️XC-70's.
If you mark the old rack with paint, and transfer your markings to the new rack, I think it WOULD work, as long as the bolt pattern lines up. Make sure you have the same amount of exposed threads on your outer tie rod, then compensate for 2cm length difference by threading your outer tie one more turn.
Then see if a shop can align it. Don't tell them what you did because they may not want to touch it if you mention the swap.
May I ask why you'd want to this?
Old May 25, 2023 | 08:42 PM
ionlyski's Avatar
I kinda doubt it. Such a bugger of a job, you need to perform every step perfectly because you NEVER want to tear back into it after you have filled all the fluids and put everything back together only to find a problem, leak or otherwise. I have done two racks on xc70s, a 2004 & 2005 and even there, the one used threaded fittings and the other used the snap in type (which is rarer) But those lines are steel and not flexible so everything has to line up just right to even get the threads started. Buy a good rebuild rack from a good company for your exact car.
TheStuckBolt
Sep 11, 2022 09:29 AM
kiddshoxx@gmail.com
Aug 13, 2022 07:32 PM
christopherandrews1989
Canada, Over Seas & Elsewhere
Oct 4, 2016 06:42 AM
Miga
Aug 24, 2016 12:40 AM
Volvo70
Mar 18, 2007 03:22 PM
