Where to place O ring on XC70 oil filter?
Two weeks ago, I posted a message here requesting information on how to change the oil filter on a 2006 XC70, specifically where does the O ring go. Just one response, and that was a suggestion to check the archives.
I checked the archives several times, but I could not find any post that gave details on how to position the oil filter O ring so that the canister does not leak. Compared to forums on Roadfily, where you can expect a dozen or more veryhelpful replies to just about any question or issue, this forum is fairly inactive. Can I get some help here or can someone direct me to a forum where I can get some serious responses? My thanks. |
RE: Where to place O ring on XC70 oil filter?
I just changed the oil filter on our 2001 yesterday. First off, take the filter canister cover off and you should see the old o-ring on it. If it is there, simply put the old one in the same place. On ours, I had to put the o-ring on the lowest groove (the one fartherst from the open end of the cover)
Hope that helps |
Oil filters for this car are the cartridge type. Your replacement paper filter should come with a large diameter O-ring. The O-ring fits around the base of the plastic housing that holds the filter. There is a circumferential grove in the housing for insertion of the O-ring.
