XC70 3.2 engine noise at idle
Old Jul 5, 2021 | 06:22 PM
Fernando's Avatar
Default XC70 3.2 engine noise at idle
Hi
In my Volvo XC70 2010, 88.000 km 3.2 engine, I am experiencing an engine noise, that I can not find where is it. It happens stopped at idle but with some little effort of the engine, like transmission in D or R, or in neutral turning a little bit the steering.
The noise change when you take out the oil cap, but for a while and the appears again without the cap in his position.
I have changed water pump, belt tensioner, belt and the idle roller, Checked the vacuum pump and I found a little play (I am importing a new one) , thinking it was the problem I took away the blade that the vacuum pump has inside, put the cover on again without the blade and I run the engine, same noise.
I attached a video, I will appreciate any help, thanks in advance
Old Jul 5, 2021 | 06:35 PM
Fernando's Avatar
I send the video again, it was corrupted
Old Jul 5, 2021 | 07:15 PM
Have your checked the PCV box to make sure it is working properly - taking the oil cap off will change the crankcase pressure.
Old Jul 5, 2021 | 09:16 PM
Fernando's Avatar
I have already change the PCV , the complete cover is new, no changes
Old Jul 23, 2021 | 12:15 PM
Fernando's Avatar
I have found the problem, It was the steering pump, the noise was present in some revolutions of the engine only. I expect it can be useful for another member when they have a similar noise in a 3.2 engine
L8knight
Jun 17, 2021 10:30 PM
katiebug324
2001-2013 model year XC70
Apr 11, 2021 04:56 PM
dman777
Nov 21, 2010 08:57 PM
BoomeR
Sep 6, 2009 03:32 PM
woodsvolvo
May 25, 2007 08:14 AM
