12V+ wire when headlights are on.
Old Jun 20, 2007 | 01:31 AM
carlog's Avatar
Default 12V+ wire when headlights are on.
I need to tap a wire that give +12V when the headlights are on to connect to an aftermarket radio in my 04 XC90 (to dim the display when the headlights are on).
Do I need to tap into the engine compartment fuse #17 or 18? Is there an easier place to tap inside the car?
Thanks.
-Carlo
Old Jun 21, 2007 | 09:10 PM
m1964's Avatar
Default RE: 12V+ wire when headlights are on.
You could use +12V constant and tap into one of the switches that light up when headlights are on -use switched low current to switch a regular bosch relay
Old Jun 21, 2007 | 11:48 PM
carlog's Avatar
Thanks... which switch lights up when the headlights are on?
Old Jun 30, 2007 | 11:23 PM
m1964's Avatar
Use the wire from the headlight switch.
Joseph Robert Rodda
Jan 2, 2013 08:29 PM
VDriver24093
Feb 21, 2011 04:35 PM
merlinx
Dec 26, 2010 06:51 PM
CactusTaxi
Sep 2, 2010 09:30 PM
