2004 XC90 A/C not cold when idling
Old Sep 14, 2010 | 05:04 PM
joelq's Avatar
Default 2004 XC90 A/C not cold when idling
Hi all -
The A/C is nice and cold when the engine is revved, or while driving about, but not so cold when the engine is just idling. It's as if the compressor clutch is disengaging when the engine is idling.
My mechanic checked the refrigerant level, and all is OK.
Any ideas on what to check?
Thanks!
Old Jul 2, 2011 | 02:59 PM
holdene1's Avatar
same issue with my 2007 xc90..was told by a mechanic my compressor is going out and will need to be replaced?
Old Jul 3, 2011 | 09:51 AM
joelq's Avatar
I actually only just recently got this problem figured out - it was a couple things.
1 - my A/C damper doors needed to be re-calibrated. This was causing uneven temperatures to blow from the drivers side to the passenger side. Only the dealer can do this, an they charged me $140.
2 - my refrigerant was low. My mechanic said the only way to see if your refrigerant is low is to do a full A/C evac. My non-dealer mechanic was able to do the A/C evac for $90.
Problem is now solved. Not sure about your compressor, though. Does your air blow cold at all, or only at times?
Johnny Volvo
Nov 27, 2012 01:05 PM
Spyros
Jun 13, 2012 11:43 AM
Richmond850
Jun 11, 2011 07:31 AM
Steady
Aug 8, 2008 11:11 PM
clintw
Jan 22, 2008 08:05 AM
